Adding a second modbus...
I've decided to go down the modbus route with my inverters on HA. I bought a couple of Elfin ew11a's.
By following the online instructions I managed to get them both working, however...
Following having the power off to the house, the modbuses lost contact with HA.
After much messing about, I got HA to see one of the modbuses. The problem I have is that I should have added both units at the add integration stage. I added just the one thinking that it would be easy enough to go back and add the second. My question is, how do I unpick what I've done so that I can then re-add both at the same time?
Any help would be much-appreciated.
Many thanks
Greenie
Re: Adding a second modbus...
You'll need to delete the existing Device, restart HA and then add the integration again with both Devices you want to add.
Thanks for that, Dave. All sorted! I've even got it to stop draining my home batteries while charging the car. :D
