Forced overnight charging problem
I seem to not be the only person having a problem with forced overnight charging?
I got up yesterday morning (28/2) and noticed my electricity meter in-home display showing less than the usual amount of overnight use, and appearing to be running off the grid at that moment.
The battery had indeed not charged - it had charged from 23:30-23:59, then nothing. Looking at the mode scheduler on the app, the two forced charge periods (23:30-23:59 and 00:00-05:29) had Charging Cut-off SOC set to 10% and Charging from Grid set to disabled. I set these back to 100% and enabled, and last night it seemed to charge OK again.
So I only lost about 24 hours of battery use, but this is pretty poor. There may be many customers who set their system up (or had it set up for them), and don't regularly monitor things, who would only notice something was wrong weeks or maybe months later when their electricity bills are more than expected.
Re: Forced overnight charging problem
If you're able to run a python script I did a simple one that will overwrite all the schedules in 1 go.
viewtopic.php?t=2859&start=25
