Two strings but P2 shows 0v
I have a recent PV install with 12 panels. Both the PV1 and PV2 inputs on the Fox ESS H1 inverter are connected, and on a sunny day (not many so far), the power indicates over 4.5kW (so the 450W panels seem to function).
But on the display panel, P1 shows a healthy voltage, but P2 shows zero (or very nearly).
I did a Google on this scenario, and one suggestion was that the PV config was set to "independent" - but I can't find this information again! The PV config for my H1 is set to independent.
I have the manual for the H1, but it doesn't go into any detail about the options listed in the function tree.
Thanks.
Re: Two strings but P2 shows 0v
It sounds like your 12 panels have been wired as 1 string into PV1 and there’s nothing in PV2 - what panels do you have, and what voltage are you seeing on PV1 during the day?
Thanks.
The panels are JA Solar 450W units with an o/c voltage of 39.3v (so 12 would be a max of 471.6v). The inverter has a max input of 600v, so that does seem to be compatible.
I read that 1 string is typically more efficient than 2 (my roof has no shade except passing birds and the clouds).
It's just that I have conflicting and confusing answers from my installer. The system spec mentions two strings, and the 4-core cable to the roof is connected to both PV1 & PV2. So, where does PV2 go if the panels are 12 in series as 1 string?
I'll have to get back to you on what voltage is shown as soon as the sun comes out again. [unless the inverter has kept a log somewhere]
Grumps wrote: Thu Feb 19, 2026 9:14 pm I'll have to get back to you on what voltage is shown as soon as the sun comes out again. [unless the inverter has kept a log somewhere]
Check this post viewtopic.php?p=13135#p13135
Now select your Inverter, and filter PV1 & PV2 Voltage
