I have a new install of FoxESS KH10 inverter with Solar, connected to my HA using USB to RS-485 adapter. I have installed modbus, and I can see the inverter on HA. However, I am unable to find the controls for limiting import and export. For e.g., currently the export prices are negative and my battery is full, I would like to stop export.
Appreciate any pointers.
Sandeep
So when U say your export is - are U saying they are charging u to export ?
That's crazy, I'm sorry but I don't have any recommendations for you, but you would think there would be a setting to turn the inverter off once battery has reached 100% , my best advice would be offer all the neighbours extention leads & tell them to use the excess power.
Does the excess Solar occur at random times, or fixed?
If it is fixed times, can you not set an automation to force discharge beforehand for a few hours so the battery has capacity to mop up your Solar generation. To protect the discharge session from draining on a dull day, make sure to add in And-if "SoC" is above xx%
Example, If time is 09:00 to 11:00, and if SoC is above 50%, then set Work mode to discharge
I am new to Home Assistant, but I am sure that you can make it do something like this.
Sandeep,
You are on Amber like me. I am not sure this will work but can you adjust your grid export limit to zero while this occurs?
Thank you Simon for your input, you are correct, if you are able to adjust this value in Modbus that would work for the best.simonsthill wrote: ↑Mon Jan 19, 2026 10:28 pm Sandeep,
This is exactly what I wanted to do, but don't know how. Appreciate your inputs, thanks.simonsthill wrote: ↑Mon Jan 19, 2026 10:28 pm Sandeep,
You can also use the service once you know the registers to set and reset the export limit.
I don't know the values as my solar is ac coupled and I already can do this with my old solar inverter. Fox is just battery for me.
There is also a read service too so you can go poking around and you can verify the values by changing in the app.
foxess_modbus.write_registersI don't know the values as my solar is ac coupled and I already can do this with my old solar inverter. Fox is just battery for me.
Thanks. I am aware of the write registers, but don't know the addresses. Also, is there a limit on number of writes?aliens9531 wrote: ↑Tue Feb 10, 2026 8:55 pm You can also use theservice once you know the registers to set and reset the export limit.Code: Select all
No limit on writes as far as a I know, Changing other modes settings in the home assistant addon does the same writes anyway.
