Does anyone know please where the battery charging settings are now? They were under Quick Settings, where I could set the time for battery charging.
The mode scheduler appears hidden too.
Many thanks
The Grid Charge settings are now under Device, Battery and you’ll see them at towards the bottom of that page (they are called Force Time Charge).
If you want to find the Scheduler that used to be under Quick Settings, that is found by clicking on Work Mode and then click on the 2 arrows to the right of your current work mode, Scheduler is at the bottom of that page.
