Help appreciated please, as customer services for installer and manufacturer are not working at the weekends
I had some late night fiddling on the FoxCloud2 app when my cheap rate kicked in at midnight and I noticed that the batteries were not charging using the settings I did with the electrician. Eventually, I hit on something (or something updated) after watching YouTube videos, and they started to charge. I happened to wake up at the end of the cheap charging period (ends at 5am) and saw that they were only at 33% (after about 4 hours). So 33% of my potential 24ish kWh. I used some of the stored charge, down to about 11 %, and then, it being a sunny day, the excess power is happily charging up the batteries.
My questions are -
A) is my 8 kw inverter capable of fully charging my two EP12s within my 5 hour cheap rate window?
B) During my cheap rate, I have a lot of load - storage heaters and other things. Will the batteries charge up independently of all these other things, or is only so much coming into the house/through the inverter, and will serve the house first and THEN attend to charging up the batteries? When I saw that the batteries were charging at around 1am, there was a 6.5kWh load on the house. This may have gone down as storage heaters had their fill. Is this a factor?
Thank you so much in advance.
