Please anyone please confirm what the settings should be on the Inverter for the EPS.
Should this socket be live when the system has grid power or is it only live when they grid goes down?
Thanks,
Darren.
Settings are dependent on the type/way of your EPS installation but commonly you'll want the following.
Settings > Off Grid > EPS (Enabled)
Settings > Off Grid > UPS (Enabled)
Settings > Feature > Bypass relay (internal)
It's important to ensure you have a PE as during a powercut TNCS system will lose grounding/earth so most installs will require an earth rod.
