It's certainly cold
Suddenly it has started charging from the grid at other times.
One day it discharged down to min SoC around 12% by 3pm then started to charge up until nearly 9pm then discharged until 11:30pm, the correct charge time.
The other day it discharged down to 12% late morning, then at 13.30 started to charge for 4.5 hours to 60%, discharged for 2 hours to 20% then charged again for another 3.5 hours.
All the above are outside the set charge rates and interestingly all the charges are at exactly 0.84kW which makes me think it's a setting in ther BMS?
I've checked the inverter and no fault logs and date/time are correct?
I have the battery heater set to come on on the low tariff hours as well.
Anyone got any ideas why?
Edit Just noticed the same thing has just started for the third day!
