All makes sense and thanks for the detailed response! Just to clarify yep am in the Australian market.
Understand what you are saying and your calculations makes sense. However, assuming your theory is correct it presents some contradictions:
- 1. Using only the Fox app, when the battery says 100% it also says 41.9kwh as "Remaining Energy" right below it. When the battery gets to 10%, it says 4.1kwh as "Remaining Energy". That indicates the reserve value is included in the figures when using percentages.
- 2. If the Remaining Energy is displayed incorreactly and it is a bug in the fox app: at 100% SoC, the Remaining Energy should be 37.7kwh (as opposed to the 41.9kwh), and when it gets to 10% it should also say ~3.8kwh (as opposed to the 4.1kwh). If that were the case, the software doesn't allow discharging that remaining 10%. That would mean Fox is not allowing use of 19% of the battery capacity (a. 100% * 10% = 10% of battery reserve, and then b. 90% * 10% = 9% due to the software limitation).
So in either case, there is either something wrong with the app figures, and in both cases, we aren't able to access the full battery as specified. At best we are missing 10% capacity, and at worse we are missing 20% capacity.
All can be reproduced using Fox Cloud stats, home assistant is just a handy way of graphing and logging that data at a good higher interval. So I definitely don't think it is a home assistant issue.
But as you suggested will write to Fox and see what they say.
Hope that all makse sense! Again appreciate the response in trying to figure this out!
