Oauth redirect flow issues
When initiating the OAuth authorization code flow, the FoxESS auth page does not redirect to the configured redirect_uri, so the application never receives an authorization code. In DevTools Network, only two XHR requests occur (/oauth2/login and /oauth2/getRedirectUri). No top-level navigation/302 to the callback URL is observed.
OAuth config / parameters
• client_id: f8f7900d6c7f47049413f482ce242d6d
• redirect_uri: https://wattion.app/api/foxess/oauth/callback
• scope: data_access device_control
• response_type: code
• state: (random string per attempt; example: X4bV3q1Htha_lXEOAELz8JdkexFUywEE)
URL looks like this
https://www.foxesscloud.com/h5/auth/fox ... dkexFUywEE
and I'm expecting a redirect like this
https://wattion.app/api/foxess/oauth/ca ... ate=<STATE>
1. What does code: 41825 indicate in /oauth2/getRedirectUri?
The response includes supportDevices but also msg: "Unrecognized msg:41825".
2. Should the page perform an additional request / step to trigger the redirect (e.g., device selection / consent)? If so, what is the expected endpoint / UX?
3. Is there any requirement that the redirect_uri be whitelisted exactly (including trailing slashes / https only / etc.) beyond what’s shown in the personal center settings?
Re: Oauth redirect flow issues
I assume you've read the notes on OAUTH here?
https://www.foxesscloud.com/public/i18n ... ument.html
Part of this says that OAUTH is only available in licenced code mode - I don't know if this means your application has to be registered and authorized by Fox ESS before OAUTH will work.
When you look in the app, supported services that are registered to use OAUTH are listed. For example, Capture and Axle.
H1-6.0-E hybrid inverter
6 x HV2600 v2 batteries
16 x JA Solar 405w panels
7 x Tigo TS4-A-O optimisers
Yeah I saw that and it wasn’t clear what it meant. Couldn’t find an answer for a few searches but would be good to get a definitive answer from foxess support
