PVOutput
How many PVOutput users do we have here? I'm (supposedly) feeding data into PVOutput, but it's not behaving as expected. I set it up using Tony M's excellent guide. I've tried accessing the PVOutput Forum, but can't, and no way of contacting them, as far as I can see :cry:
24x Eurener MEPV 450 panels - FoxESS KH8 inverter - FoxESS EP11H battery
Re: PVOutput
Working for me.
What are you seeing that makes you think it isn't working as expected?
How are you uploading your data?
H1-6.0-E hybrid inverter
6 x HV2600 v2 batteries
16 x JA Solar 405w panels
7 x Tigo TS4-A-O optimisers
Re: PVOutput
Thanks Tony - I was hoping it would be you who would reply :)
This is what I mean:
Only sporadic entries in the Generated column.
I followed your guide:
  • rest_command.yaml created
  • secrets.yaml edited
  • rest_command line added to configuration.yaml
  • Template sensor added to configuration.yaml
  • Automation created and tested
The fact that the data is being uploaded, albeit sporadically, kinda suggests to me that the config is correct, otherwise nothing would be uploaded, right?
