Looking at a EQ4800-L9, setup outside. Wanted to know what recommendations there are for securing the unit? With the modular design, do they lock together to atleast make it very heavy to mess with?
There is a battery mounting screw per battery that stops each battery being separated - the standard screw can be replaced with a security screw and threadlocker used which will effectively join them as a single (very heavy ~350kg) pack and the battery master can be fixed to the wall with brackets.
If you need more security than that, you would need to consider fitting an enclosure.
