mira fox inverter 3.6kw
can some one please help
dull day today so i force charged for an hour but much much later its still running off grid and i dont know why, i dont seem able to get it to run off battery as it normally does i use octopus flux import 2am -5 and export if required after 4 on mode scheduler but its still importing from grid ive reset the inverter loads of time and looked at the app on my phone and laptop but its the same i will have done something but not sure what battery is 65% but im drawing from grid and missing the battery charge that i wanted, what have i done help please
force charge was for an hour ! am lost right now
Re: mira fox inverter 3.6kw
Ive also just noticed that the inverter panel says OFF Mode but i cant get it on so now the house is just running from grid missing the batteries and the force charge used for flux has stopped working it appears that the link between the inverter and the load in the house is missing on the app where it shows the energy flow i am not sure how to resolve this if anyone can advise please it would be welcomed
ive noticed now it says on inverter off mode says Active Err 1/1 safetyinvalid advice please
I think you need to start by doing a full shutdown and then restart the inverter and go from there.
To shut down the system, you will need to isolate the solar (PV), isolate the grid (AC) and then switch off the battery - after approximately short while the inverter display will go off then reverse the process.
Power on the battery, switch the grid (AC) on, switch the solar (PV) back on
if you are not familiar with that process there is a video in guides that explains more here https://foxesscommunity.com/viewtopic.php?t=5
Thanks for the reply ive done it numerous times and the error still persists ive managed to check that the G98 is in settings but it still wont run now at all officially broken
Inverter just says OFF MODE
Press and hold the ‘enter’ key (3rd from left) - when it says Start ?, release and press it again - the inverter should start up.
Thanks for the reply i will give it ago but i wont be back home till Tuesday now
i tried it yesterday though and it dint work i will give it a shot after a full restart and report back Thanks for your help
ImageImageImageHi ive tried all the resetting instructions a ssoon as there is power to the inverter it comes up with the message Active Err 1/1 Safety Invalid ive tried to boot the inverter without batteries and its still the same Image
Hmm, and you have confirmed that the safety is set correctly im Settings > 0000 > Feature > Safety - should be G98_UK
Failing that, I would contact either your installer or Fox support (in the v2 app you select Me, Contact Us, Support) - possibly a firmware update will help, but it could be because of a hardware fault and it needs some remote diagnostic.
This is all i can come up with
Fox ESS H1-3.6 kW showing Active Err 1/1 Safety Invalid.
Occurred immediately after force charge.
Grid code is UK G98.
Error appears immediately on boot.
Please re-push G98 safety profile / re-commission inverter.
Please Advise Many Thanks Paul
Sorry missed the post yes its set to G98
i have spoken with the installer who says they will raise a ticket with the fault the installer is UPS solar i have been chatting to Denis
Many thanks Paul
Hi Dave
Ive done as suggested raised it through the app which was an easy process
Think ive waited long enough they dont reply and you dont know whats wrong am gonna have to get a replacement inverter with the support i need i cant wait this is crap i dont need this kind of no support thanks for your help any ways
gonna wait till tomorrow then im off to just get that crappy thing off the wall
i have had an engineer here for three hours with a laptop this morning problem solved all working all settings removed and restored
Paul wrote: ↑Wed Dec 17, 2025 9:29 am i have had an engineer here for three hours with a laptop this morning problem solved all working all settings removed and restored
Ok great, glad you’ve got it working again - it did sound as if the settings had been corrupted, good result !
Something to do with grid settings being corrupted by force charge just left him to it
Thanks for your help on this it saved me getting a new inverter
