I currently have a KH9 and 20KWh ECS2900 Battery system with 12kw solar and been running for nearly 2 years now absolutely perfectly and covers all the house demand easily.
However, This year I had a heat pump installed and during these winter months with little solar im finding that i could do with an additional 10kwh of storage to cover this extra load.
On the face of it I can see i have 2 options (let me know if I have got this right):
1) Replace the ECS2900 (20kwh) batteries with newer EQ4800 (30kwh) circa £8k
2) Buy 2nd KH Inverter and run in parallel with EQ4800 (14kwh) circa £5k
Obviously the easiest is replace batteries but this is costly and I'm not aware of a way to resell batteries (unless anyone can advise or partx service with a supplier?)
Second option more cost effective and provide more MPPTs and larger inverter capacity but these are not really advantageous to me and also takes up double the space.
Also, I was wondering if there is another solution such as buy another smaller fox system or AIO that can link with HK9, possibly to be turned on only for the winter months when needed, or any other system that I can roll in for the winter months when the extra capacity is needed? Does anyone else have this issue and overcome it? Or even a third party system that can be rolled in during the winter months?
Thanks all
