F3600 string inverer
Hi folks is h very a fox f3600 reasently installed and have been told that need to install a ct clamp to be able to amounts going to the grid and house. But this needs to be attached via a plug on the base of the inverter.
Does anyone know the part no or where I can buy this plug
Re: F3600 string inverer
The plug should come with the inverter, it’s usually left in the bag of bits left by the installer or contact your installer and see if they have one, if you don’t have it you will need to email fox support and see if they can point you in the right direction.
Wondering if this is the connector you need ? https://www.ebay.co.uk/itm/376095248383
