Question: Modbus Register Addresses - Stack vs Cluster for G-MAX Battery
Dear Fox ESS Support,
I am integrating a G-MAX Series Hybrid Inverter via Modbus and need clarification on battery register addresses.
The documentation shows two sets of registers:
Stack level: 200 (SOC), 224 (power), 227 (charge), 229 (discharge)
Cluster level: 2200 (SOC), 2224 (power), 2227 (charge), 2229 (discharge)
Question: For a single battery G-MAX system, which addresses should I use - stack (200/224/227/229) or cluster (2200/2224/2227/2229)? What is the difference between these register sets?
Thank you for your help.
Best regards
Ivan
