How to force charge up to 60% and self use above 60%?
Hi. In the app FoxCloud2.0 "mode scheduler", I set "work mode" to "force charge" and "min SOC on grid" to 60%.
As expected, when the battery is below 60%, this charges the battery up towards 60%.
However if the battery is above 60%, I expected any load to consume from battery, down to 60%. Instead the load consumes from the grid.
How can I change this so that the battery force charges up to 60% and the load consumes any battery above 60%?
Re: How to force charge up to 60% and self use above 60%?
Sadly you cannot, that’s how it works when it is in force charge it charges to the desired % and then holds it powering the house from the grid.
