F3600 MPPT
Recently i observed some strange behavier:
The F3600s output is permanently altering between very low (~20W) and high (1.2kW).
My setting: String 1 (4 * 415W) north of the Building, now most of the time full shadow.
String 2 (5 * 415W) south of the Building mostly full sun.
String 1 disconnected: Pout 1.2kW.
String 1 connected: look above.
My question: How independent are those MPPTs?
Is there a Firmware-Update adressing this problem? (Version now:1.51/1.05/2.31)
Thanks for your interest!
Re: F3600 MPPT
Can you post some graphs or screenshots of the problem to help understand the issue?
Are you using optimisers in your strings? if so could one be faulty?
Re: F3600 MPPT
Hi and thanks for your answer!
I admit using Optimizers in String 1, but i cant understand how those bring down String 2, as the Tracker are announced "independent".
