Hi folks is it correct that a fox string inverer will only display solar amounts and not grid or house usage
Yes out of the box and without an optional meter/ct connected a solar only inverter doesn’t provide that information.
If you’ve charged fit the optional meter you will get real time load and grid consumption graphs but not the long term daily/weekly/monthly statistics (although you can use a home assistant to do that for you).
So if I get a ct clamp fitted i would be able to view usage and grid amounts on the appDave Foster wrote: ↑Wed Oct 22, 2025 6:24 pm Yes out of the box and without an optional meter/ct connected a solar only inverter doesn’t provide that information.
Yes the current load and grid use, just not the daily cumulatives.
Most people install a home assistant which connects to the fox cloud and will allow you to maintain full statistics as well.
