Modus Terminierer funktioniert nicht
Hallo,
mein Modus Terminierer in der App funktioniert nicht.
Der Speicher hält sich nicht an den festgelegten Modus und auch nicht an die festgelegten Grenzwerte.
Ich habe einen Avocado Orbit-M -Speicher.
Anbei Screenshots als Beleg.
We can also communicate in english If someone has Had the Same issue or can help me.
Re: Modus Terminierer funktioniert nicht
Hello Juan!
Unfortunately, I can't help you, but I hope someone else will get in touch. The scheduler isn't working for me either. In fact, none of the discharge modes are working for me. I've set the operating mode to feed-in priority, but the battery still isn't discharging. The setup worked fine, but since then the battery has been full and is of no use to me.
Best regards, Klaus
Hey Klaus,
Thanks for your Response.
Do you have a smart Meter installed?
The FoxEss -Support told me, via a Ticket which I opened, that this is necessary for a schedule.
Thanks and best regards
