Where to start
Hey
Just got HA setup.
I obviously have a Fox ESS battery and inverter along with an Octopus mini.
Are there any apps or easy ways to get data on my solar production and energy usage?
Also how do you setup Solcast for forecasts?
Re: Where to start
welcome to the rabbit hole ;)
The Octopus integration by Bottlecap Dave is excellent and will provide a mine of information about your utilities, not least current tariff and events that trigger when things occur like saver sessions, switching tariff etc.. - it can take some time to master everything it can do but if you install that for starters you will be able to see a lot of data.
Solcast(.com.au) is an Australian solar tracking tool and it will allow you to create a hobby account that can have 10 observations a day, create an account there and then install this ha integration to manage it for you https://github.com/BJReplay/ha-solcast-solar that will provide up to 7 days solar forecasts and today and tomorrow which are normally pretty accurate.
Have you installed a modbus connection to the inverter ?, if you haven't yet it is the best option - more details here https://github.com/nathanmarlor/foxess_ ... ring-Guide, another alternative to get you up and running quickly is to interface the Fox cloud using their OpenAPI, this integration will do that for you https://github.com/macxq/foxess-ha and once setup will gather your 5 minute data samples and statistics very much as you can see in the app, you can then add things to the energy dashboard and it will track grid, battery, solar etc..
Will has done a really good video on how you set up the Fox modbus or cloud integrations, you can see that here https://www.youtube.com/watch?v=kE_6HtzcyXg
Re: Where to start
Hey
Thank you for the reply!
I will look at the Octopus Intergration. Thanks
I have Solcast setup, it was saying we should have generated over 2kw of solar, but I am on 0.6kwh... Says today we will prodice 13.94kwh, we will see.
Is there a quicker (and nicer) way to view the Solcast data, it is a pain having to go settings>Device and services>find Solcast. It has also put the order as:
Forecast day 3
Forecast day 4
Forecast day 5
Forecast day 6
Forecast day 7
Forecast next hour
Forecast remaining
Forecast today
Forecast tomorrow
I want that re-ordered but cannot see how.
I do not have a Modbus installed, whilst it would be a dream, it is not practical to run ethernet that distance.
Re: Where to start
The solcast integration isn't perfect unless you have a clear unobstructed line to the sun, last few days it's been getting cloud cover wrong for me - there is on the latest version an automatic dampening setting, I haven't used it yet myself but it's supposed to look at the past 14 days and apply a factor to your solar to automatically correct it for low elevation etc...
If you have Fox cloud set up, you can add your PV to the energy dashboard and when you add it (or edit it) you can select forecast production and select solcast - that will then give you a visual representation of your solar forecast vs your actual generation for the time of day.
You can add the solcast sensors to your dashboard in devices and services, underneath the list of sensors it will say 'Add to Dashboard' - click that, tell it which dashboard you want to add it to and then you will see it there.
To change it, you just need to edit the dashboard 'card', you do that by clicking the 'edit' pen icon in top right corner, select the card you want to edit and you can delete, or change the position of entities in the card.
Re: Where to start
So i have found my Invertor SN and the Fox Cloud API, but it requires a device ID, where can I find it?
Also, tried to create a new dashboard, but when i added Solcast it says:
Solcast PV Forecast
Only one Solcast instance allowed
Re: Where to start
oxfordmark wrote: Thu Oct 09, 2025 11:18 am So i have found my Invertor SN and the Fox Cloud API, but it requires a device ID, where can I find it?
the deviceID was only used for really old installs before the OpenAPI was developed so now just use your inverter SN for both the ID and SN
i.e. it would look like this
sensor:
  - platform: foxess
    deviceID: inverter_serial_number
    deviceSN: inverter_serial_number
    apiKey: your_api_key
Re: Where to start
Hey
Done that, when i try to add the HA Fox ESS intergration it says:
This integration cannot be added from the UI
You can add this integration by including it in your 'configuration.yaml'. See the documentation for more information.
I have deffo added this:
10
11 scene: !include scenes.yaml
12
13 sensor:
14 - platform: foxess
15 deviceID: 609H5020530000
16 deviceSN: 609H5020530000
17 apiKey: ec7f8f27-0000-0000-0000-d7a8448f0000
Have 0'd out some of the numbers
Re: Where to start
It's not obvious whether you've got the spacing in, but spacing is critical - so the - platform should be 2 spaces in from the sensor (the - would be under the 'n' of sensor:) and then the rest should be 2 spaces in so they line up under the 'p' of platform.
It's correct in that you can't add it from the UI, only from the configuration.yaml
You must restart HA once you have added those lines and if you go to Devices and Services after the restart it should be showing an HA & Foxcloud integration with a number of entities you can then add to your dashboards.
Re: Where to start
Dave Foster wrote: Thu Oct 09, 2025 12:05 pm It's not obvious whether you've got the spacing in, but spacing is critical - so the - platform should be 2 spaces in from the sensor (the - would be under the 'n' of sensor:) and then the rest should be 2 spaces in so they line up under the 'p' of platform.
Can you DM me and i can send a screenshot.
Re: Where to start
It is working!!!
How do you get decent data from this? Like historical graphs etc?
Also what sensors are good to display.
Re: Where to start
Great, the best sensor to add to your energy dashboard iare PVEnergyTotal - that is the total PV production for today, if you add that as a solar generation source and use the Solcast as it's forecast when you set it up - you'll see what you generated vs forecast in the Energy dashboard.
Also add grid consumption as your grid consumption, feedin as Return to grid, in the 'battery energy in' use bat charge, and energy out use bat discharge.
The best sensors to watch are these as they are totals for each day
battery discharge, battery charge (charge/discharge for today), feedin, grid consumption, load, PVEnergyTotal, Residual Energy (your battery left kWh), Bat Soc
If you click on the one called Inverter, and then drop the 'attributes' at the bottom it'll list all your firmware versions and for your batteries
PVx Power, load power, grid consumption power, are good to watch as a gauge for how much power is coming in 'now'
Energy Generated is not so useful if you have a hybrid as it is the same as total yield i.e. all the work the inverter has done either via solar or battery.
Re: Where to start
Re: Where to start
Not sure what your ‘from the grid’ sensor is as i’d expect the battery charge power to be similar to that coming from the grid, the sensor I would use is ‘Foxess - Grid Consumption’. The rest looks good.
Re: Where to start
I don’t have that grid consumption sensor on my set up.
Re: Where to start
That’s weird, it’s a standard sensor unless it’s been renamed to ‘from the grid’
If you go to Devices & Services, and click on the 69 entities of the HA & Foxess Cloud integration - do you see any that relates to grid power, grid consumption
Re: Where to start
Yes I can see “grid consumption power”
Re: Where to start
Could you screenshot the entities list with the grid consumption power near the bottom of the screen so I can see what’s above it.
Re: Where to start
I’ll need to do this at work as can’t get to an image hosted.
Re: Where to start
Hey
So i wanted to track the temp of my battery. The app was showing the battery as under 10oC yesterday evening, but it is showing that it never dropped below 18oC!
https://ibb.co/BVwPDrHw
Re: Where to start
oxfordmark wrote: Tue Nov 18, 2025 9:26 am Hey
The app shows you the lowest cell temperature, whereas the cloud reports the BMS ‘battery’ temperature which is usually 6-8C higher than the lowest cell. Fox did say they would add this parameter to the OpenAPI data but it hasn’t happened yet… fingers crossed.
Re: Where to start
I’ve been using a solar prediction site which was quite accurate. “Solar PV Forcast” adverts driving me mad and didn’t want to pay.
Have now joined Solcast through the Energy Stats app and it seems to double my prediction. I’m sure I’ve set it up correctly. In fact the same as my previous app.
Any ideas what I’m doing wrong ?
https://freeimage.host/i/fMYYt99
7.2kw PV
16 x 450w JA Solar All Black
12 x SE
4 x NW
Fox H1-5.0-E-G2-WL Inverter
Ohme Pod Car Charger
Re: Where to start
Not sure whether it's the same but my solcast forecasts are not accurate at this time of year because of the suns extremely low elevation, today for me says 5.5kWh but i'll be lucky to see 3.5kwh - they are much better March through October.
If you do make the move to home assistant the solcast integration has an automatic dampening feature which looks at the last 14 days data vs forecasts and applies a dampening figure to even it out.
