Hi my Battery pack is stuck at 49% and says it is discharging 0.017kw. This has remained constant for the last 48hrs regardless of what is turned on in the house. I've tried turning power off and on but nothing. Any help would be most appreciated.
It sounds like we are having the same problem. My installer said it’s due to the cold weather as inverter and batteries are in my attic.
Hi All,
We got up to 2 °C yesterday, batteries now back to normal. So it is the cold that is causing the problems with the System being in the loft. I'm going to make an enclosure with sheets of lagging. Hopefully the weather will improve, and
This isn't something that will happen much.
I should have had it in the garage where I suggested in the first place.
