Data Export
RedArrow
I have started to used the Data Export of V 2 of the app and I am interested in Battery Charge and Discharge amounts but cannot see a way to export this data.
Can anyone shed a light if this is possible.
In the Data Report section of the V2 app if you add your inverter serial number, select the date range and select 'Standard' reporting and submit, then 'Download' the data - this will download the .csv to your downloads directory on your device.
Within the .csv are a number of fields including 'InvBatPower' which is the battery power in kW a negative value means charge, positive value means discharge.
Or you can use the InvBatCurrent (A) and InvBatVoltage (V) where Battery Power = A * V again a positive value means discharge, negative charge
