						FoxESS H1 5kW and Wave share modbus...
						Posted: Thu Jul 04, 2024 11:04 am
						by TheDomOfThree
						Hello All,
this is my firs one here so please be patient. I own FoxESS Hybrid inverter H1/5Kw (Master 1.65, Slave 1.02, Manager 1.70). I have decided to connect this thing to my Home Assistant instance so did a bit of a research and decided to go Waveshare route. I have purchased one from PiHut.
So this is where I need your help. I managed to set up the hardware (correctly I believe). I have LAN access to the device via web browser, can PING, can interact with the device. I have blue light on RS484 ACT - which according to the Waveshare manual means RS484 sends data to the Ethernet. I have FoxESS - Modbus integration downloaded to my HA and so on...
Where it all fails is when I am trying to add the modbus in HA. I get that - apparently very common - error that no data has been received.
I tried reconfiguration of the device as per GitHub instructions, tried the factory reset that was suggested in the same post. Did not get any luck. I also tried the direct Ethernet port, however no luck here either - tried both DHCP or static IP, the Ethernet port on the inverter seem to be dead.
I know some users here use the same device, so I would like to ask users to share screen shots of working Waveshare configuration - I am almost sure my configuration is messed up as there is not much in terms of instructions for the RS484 interface on the inverter. The only available option in there is RS485 device ID that is set up to 247 by default.
						Re: FoxESS H1 5kW and Wave share modbus...
						Posted: Thu Jul 04, 2024 2:05 pm
						If your ACT light is on permanently you have got the A & B wires crossed, it should be flashing with activity otherwise off.
On the inverter you want to make sure that any ethernet capabilities are disabled, and DHCP is off, the only setting for RS485 is slave id which is correct at 247
The settings shown on the wiki page are correct for this device
 https://github.com/nathanmarlor/foxess ... TH-%28B%29
						Posted: Thu Jul 04, 2024 3:09 pm
						by TheDomOfThree
						Fixed. Got confused with Wavewshare manual entry suggesting that my wiring was correct. It was not. Thank you very much...
Inverter added, however, I can see only 13 entities... None of them is related to actual solar generation... Tried removing and re-adding the device - same result... Any ideas??
						Posted: Thu Jul 04, 2024 3:12 pm
						Can you go to Settings, Devices & Services find 'Foxess-Modbus' and click on the '1 Device' - what sensors do you see there ?, could you take a screen shot of what's available.
						Posted: Thu Jul 04, 2024 3:19 pm
						by TheDomOfThree
						Dave Foster wrote: ↑Thu Jul 04, 2024 3:12 pm
Hope this works.
						Posted: Thu Jul 04, 2024 3:22 pm
						TheDomOfThree wrote: ↑Thu Jul 04, 2024 3:19 pm
Hope this works.
It didn't embed them, but I can see they are google drive objects - i'll take a look now.
						Posted: Thu Jul 04, 2024 3:29 pm
						Hmmm, that doesn't look right - can you confirm which version of Home Assistant you are using (Settings, About), particularly 'Core' and also which version of the integration it is (you'll see that by clicking on HACS, Integrations and click on Foxess Modbus)
When you added the device do you select 'TCP' or 'Modbus RTU over TCP'
						Posted: Thu Jul 04, 2024 3:37 pm
						by TheDomOfThree
						HA
Core 2024.7.0
Supervisor 2024.06.2
Operating System 12.4
Frontend 20240703.0
HACS
Integration version:	1.34.0
Frontend version:	20240119163101
Repositories:	1390
Downloaded repositories:	5
Foxess modbus version is 1.11.1 as per repo version.
When adding the inverter I did the TCP.
						Posted: Thu Jul 04, 2024 3:42 pm
						Ok, there's the problem there - you are running the latest version of HA Core and unfortunately it has introduced a breaking change to the integration - this should be fixed shortly, but for now it's easy enough to fix it by reverting your HA core back one version.
You can do that by opening a Terminal window and typing
 ha core update --version 2024.6.4
That will roll you back one version and when it restarts check the how many entities you now have running
						Posted: Thu Jul 04, 2024 3:46 pm
						by TheDomOfThree
						Who are you Almighty Wizard Dave?? I am on 89 entities now
						Posted: Thu Jul 04, 2024 3:52 pm
						TheDomOfThree wrote: ↑Thu Jul 04, 2024 3:46 pm
lol, i've done it a few times and quite close to the integration code
89 entities sounds good, there are more entities available but they are left disabled by default as most people don't use them - EPS voltage etc.. and they will just bloat your database really quickly, if you do want them you can enable them.
I'd recommend you download the charge card which lets you see the normal charge periods
https://github.com/nathanmarlor/foxess_ ... eriod_card
						Posted: Thu Jul 04, 2024 4:13 pm
						by TheDomOfThree
Already working on custom dashboard,  mainly for mobile devices...
Dave Foster wrote: ↑Thu Jul 04, 2024 3:52 pm
Nice one. I will be probably closer o to understanding the code on my retirement... For now not enough days in the week...
As for now thank you very much, have a fantastic day!! Back to setting up my individual devices...
						Posted: Tue Jul 16, 2024 9:42 pm
						by markhaines
I've been playing with HA integration as well, I tried to get the Charge Period Card running but get the error below:
I've made sure my (Modbus) integration is named FoxESS Inverter - am I being thick?
						Posted: Wed Jul 17, 2024 9:06 am
						markhaines wrote: ↑Tue Jul 16, 2024 9:42 pm
It’s working for me on my H1, do you have the latest version of the modbus integration ? - also when you have added the card, add it to the dashboard and then go into Edit, in the left hand pane under config you should see a drop down box, drop that down and select your inverter name - save.
