Battery is charging after force discharge during peak flux.
Posted: Thu Jun 13, 2024 6:05 pm
by RokaBoi
Hello, my installer set my battery to force discharge after I joined octopus flux. Battery discharges quickly within hour but after that it starts charging from solar rather than send it to grid during peak flux.
Re: Battery is charging after force discharge during peak flux.
Posted: Fri Jun 14, 2024 12:38 pm
If your battery discharges quickly, you might be better from 4pm to 5:59pm setting 2 items in your schedule, the first one would be to set the inverters work mode to 'Feedin First' - that will export everything you are generating (after the house load is covered) and will only charge the battery if you generate more solar than your agreed export limit (G98) which is unlikely.
Then have the second schedule item as it is now with the start time set to 6pm to 7pm and force discharge your battery.
Posted: Fri Jun 14, 2024 2:30 pm
by RokaBoi
Thank you for your reply, I have set it up like this now. Will see how it goes.
