Hi guys,
Using the mew 2.0 app and I think the figures have gone a bit wrong my lifetime load usage is 327995851kwh which is not the case at all.
Anyway this can be reset ?
App 2.0 lifetime usage stat very wrong
It appears to be a problem that affects some inverters after a firmware update, the upper byte of the loads energy becomes corrupted and it results in a very large number.
Sadly the V2 app doesn’t have an option to correct it, but the Energy Stats app for Android and ios by Al Priest does - if you use Energy Stats in the settings there is an option ‘Data’ and in there you can set a ‘Ceiling’ which filters out the corruption.
