Negative Consumption
Posted: Sun Mar 17, 2024 7:21 am
I just had an H1 5.0 E installed in the house with the battery attached. That seemed to report fine when it went in. I since had another solar array installed at the end of the garden with an F3000 inverter. Generation seems to report fine into FoxCloud (when it works!), but I'm seeing negative consumption from the grid when it's sunny.
There's no CT clamp from the garden inverter, which I'm assuming means that the generation won't get picked up by the house inverter that has the clamp, even though it's showing in FoxCloud?
I've probably left something out there as I'm still learning how it all works.
