Battery Compatibility
Posted: Tue Nov 15, 2022 12:03 pm
by Will
A list of compatible batteries for FoxESS hardware
H or AC Series inverter:
  • ECS 2900/ ECS 4100 (BMS is built into the master, cannot mix 2900 with 4100 systems)
AIO (All In One) Series inverter: Generic Inverter i.e Solax Or Solis:
Re: Battery Compatibility
Posted: Fri Jan 06, 2023 10:33 pm
by mwatt52
Is it possible to use both HV2600 and Mira 25 on the same inverter?
Posted: Tue Aug 27, 2024 12:58 pm
by Starmex
Can I use one master ECS 2900 battery without slave?
Are the ECS 2900 V1 and V2 compatible i.e. Master V1 + Slave V2?
Posted: Tue Aug 27, 2024 1:22 pm
Starmex wrote: ↑Tue Aug 27, 2024 12:58 pm Hi
No minimum spec is 1 master (ECM2900) + 1 slave (ECS2900)
You have to use all V1 for V1 ECS2900 and all V2 for ECS2900-2
Posted: Fri Mar 07, 2025 1:11 pm
by philippe_d
Are there any 3rd party batteries compatible with the Fox ESS H1-5.0 inverter?
Or more specific: is this battery compatible:
Pylontech US3000C
3.2kWh capacity per cube.
I would need 3 modules (9.6 Kwh)
If not, which Fox ESS battery (batteries) would you recommend (need ca10 kWh)
rgds
Philippe (Belgium)
Posted: Fri Mar 07, 2025 2:13 pm
philippe_d wrote: ↑Fri Mar 07, 2025 1:11 pm Are there any 3rd party batteries compatible with the Fox ESS H1-5.0 inverter?
Pylontech US3000C
rgds
Philippe (Belgium)
No there are no 3rd party batteries readily available, the Pylontech batteries are low voltage and the Fox ESS batteries are a high voltage system.
Probably the best value battery circa 10kWh is the Fox ESS EP11 which is a 10.36kWh LifePo4 battery (90% of which is usable) in a single cabinet (it is heavy at 100kg), you can scale them up to a maximum of 4 batteries if needed which needs an additional junction box to add more than one battery.
Posted: Tue Jun 24, 2025 1:42 pm
by Musoke
Hi there,
does any one know anything about the compatibility of EEL batteries?
Thank you in advance!
Musoke
Posted: Tue Jun 24, 2025 5:56 pm
Musoke wrote: ↑Tue Jun 24, 2025 1:42 pm Hi there,
Musoke
I don’t believe these batteries offer any compatibility as they are 48V low voltage, whereas the Fox inverters are high voltage LifePO4 battery packs
Posted: Wed Jun 25, 2025 8:22 am
by Musoke
Thank you Dave!
