Battery Compatibility
A list of compatible batteries for FoxESS hardware
H or AC Series inverter:
  • ECS 2900/ ECS 4100 (BMS is built into the master, cannot mix 2900 with 4100 systems)
AIO (All In One) Series inverter: Generic Inverter i.e Solax Or Solis:
LV5200.pdf
LV5200
(10.55 MiB) Downloaded 1192 times
HV2600-Datasheet-little.pdf
HV2600
(675.03 KiB) Downloaded 1305 times
energy-cube-2900-10.13.pdf
Energy Cube 2900
(541.69 KiB) Downloaded 1306 times
energy-cube-4100-little-1.pdf
Energy Cube 4100
(602.78 KiB) Downloaded 1112 times
Mira-HV25-Datasheet-8.10 (1).pdf
HV25
(562.91 KiB) Downloaded 1214 times
Re: Battery Compatibility
Is it possible to use both HV2600 and Mira 25 on the same inverter?
Can I use one master ECS 2900 battery without slave?
Are the ECS 2900 V1 and V2 compatible i.e. Master V1 + Slave V2?
Starmex wrote: Tue Aug 27, 2024 12:58 pm Hi
No minimum spec is 1 master (ECM2900) + 1 slave (ECS2900)
You have to use all V1 for V1 ECS2900 and all V2 for ECS2900-2
Are there any 3rd party batteries compatible with the Fox ESS H1-5.0 inverter?
Or more specific: is this battery compatible:
Pylontech US3000C
3.2kWh capacity per cube.
I would need 3 modules (9.6 Kwh)
If not, which Fox ESS battery (batteries) would you recommend (need ca10 kWh)
rgds
Philippe (Belgium)
Solar Panels: 15 x Phono solar 400Wp mono (6 kWp)
Orientation: South-East (136°)
Roof slope: 30°
Inverter: FOX H1-5.0E hybride (5 kW)
philippe_d wrote: Fri Mar 07, 2025 1:11 pm Are there any 3rd party batteries compatible with the Fox ESS H1-5.0 inverter?
Pylontech US3000C
rgds
Philippe (Belgium)
No there are no 3rd party batteries readily available, the Pylontech batteries are low voltage and the Fox ESS batteries are a high voltage system.
Probably the best value battery circa 10kWh is the Fox ESS EP11 which is a 10.36kWh LifePo4 battery (90% of which is usable) in a single cabinet (it is heavy at 100kg), you can scale them up to a maximum of 4 batteries if needed which needs an additional junction box to add more than one battery.
Hi there,
does any one know anything about the compatibility of EEL batteries?
Thank you in advance!
Musoke
Musoke wrote: Tue Jun 24, 2025 1:42 pm Hi there,
Musoke
I don’t believe these batteries offer any compatibility as they are 48V low voltage, whereas the Fox inverters are high voltage LifePO4 battery packs
Thank you Dave!
