Limit Export Energy
We have an instalation with T25-G3, H3-12.0-E + CUBE 2900 11,6 kWh.
Our problem is related with export limitation funcionality. We couldn't put one inverter to control the other one.
We have already tried connectiong the meter to T25-G3 and to H3-12.0-E, but it seems that FOX does not have master-slave topology for these types of inverters.
Any help please?
Re: Limit Export Energy
If you install a ct clamp on both inverters and setup the export limit on both then it will work just as well.
I never thought of that.
It's a solution, I'll add another meter.
Thank you!!!
