Hey
Just thought I'd say hi.
I have a Fox install and a background in electrical and electronic engineering.
Hey,
Welcome, could you expand on the size system you have, what inverter and/or battery system and how you're finding the results of your system?
Cheers,
Will
Cheers,
Will
Absolutely.
I've 8 x 400w panels totaling 3.2kWp on a South facing roof feeding into a H1-3.7E inverter with the Fox Energy cube with 2 slaves so totalling 12.12kWh of storage.
Whilst it's not been particularly sunny since fitted in the last month we have load shifted all our usage to Go times in addition to the generation.
Got some tidying up of the instalation to do and also do EPS properly instead of just a socket! Just in the process of replacing the consumer unit and splitting into essential loads, critical loads and normal loads.
