foxess-local: access and manage your inverter locally, without modbus
Hi fellow foxes.
A few months back I threw together a Home Assistant automation (foxess-control) making it a bit easier to use foxess inverters from Home Assistant.
In light of the recent e-Mudhra "4" debacle, I starting thinking how easy it would be for a malicious third party to gain access to our inverters, and how much damage that could cause. I then realised that my KH10 inverter uses a self-signed certificate for connecting to the cloud, and doesn't pin it - in other words, it's no stronger than an unencrypted HTTP connection, making it trivial to be intercepted, and making me more worried about the sort of security on foxess cloud.
A couple of weeks ago I decided I wanted to protect my inverter for outside influence, giving me confidence the inverter would not be exposed to being hacked, or getting bad firmware updates. That led me to https://github.com/nicois/foxess-local/ ... /README.md, which I'm using now and am pretty happy with. I thought I'd share it with anyone who has similar interests. Let me know if you like it.
While I've designed this against my KH10, it should be possible to extend to support other inverter models fairly easily, particularly if the foxess-modbus HA integration works (the web UI also accesses the same modbus registers, just on a different channel).
