Modbus Force Charge from grid but not PV
I know it's possible to set a Scheduled mode of Force Charge with PV disable but can this be done using Home Assistant and Modbus automation scripts?
Objective is to set the system (H1 hybrid) to do the above whenever the Octopus Agile rate is negative during the day.
i know PV is 'free' but when rates are -ve it means the grid has a surplus of generation so we should take from the grid to help it out.
5kW Solar Panels
H1-3.7-E-G2 Inverter
10.36 kWh Battery
Re: Modbus Force Charge from grid but not PV
Your inverter is only 3.7kW, so not going to make much a difference if you use PV or disable it to your overall house load.
What I find with Agile though, is you struggle to find things to turn on to use a lot of power for a sustained period.
Dishwasher
EV Charger
Washing machine on hot wash
Tumble drier
Oven on with door open
Unless you have an EV charger, it is hard to pull 10kW or more for over an hour, you just run out of things to turn on.
It could just be me though, perhaps other have more luck during Agile's plunge periods.
Yes, you're right, it won't make much difference but it all helps and if it can be done with automation then at least I can have my biggest load running only from the grid when I'm away.
My household is multi-generational so there's double of all electrical appliances so I could easily hit 25kW albeit not sustainable for long.
Also programming has been a hobby of mine for 50yrs so building this solar system and controlling it with HA scripts has been an absolute joy (and a bit obsessive probably :D )
5kW Solar Panels
10.36 kWh Battery
AI suggest register address 11002 for PV power output control so I'll take a look that....
5kW Solar Panels
10.36 kWh Battery
