I have a Fox ESS system which is charged overnight at economy rates or by plug in generator. I monitor usage etc using the Fox Cloud App. Is there anyway of my being notified when the grid has failed so that I can connect the generator?
Cannot say 100% this works....
Open FoxCloud2.0 App
-> Click 'Me' (bottom right)
-> Click 'System Settings' (bottom)
-> Click 'Notification' (near bottom)
Now here I am not 100% certain which will give you a notification, so it's either
-> Click 'Alert Updates' and enable 'Notification push'
You might have to enable this also, though I am less sure this is the one
-> Toggle 'Activity Notification' to on
Recommend you try the 1st choice, and if possible, simulate a mains failure to see if you get a notification.
Note you MUST have working internet of course, so if the power fails, and your router turns off... nothing will be sent.
Many thanks. Have done that but cannot simulate a grid failure so will have to await one!!
