Battery not charging after firmware update, yes, I have restarted my setup.
Hello, I noticed that my battery was no longer charging after some firmware upgrades but exporting straight to grid. Also, the app was asking me if I was connected to the network.
On further checking, after a bit of chatting with google, I noticed that my dongle was flashing red, fairly slowly, about once a second. 1st thing I did was reboot my rooter, to no avail.. Thing is, I can see information updating in the app which also says connected. <shrug>
Next thing I did was restart my set up, inverter/battery. A couple of times, left it about 5 mins. No change.
My set up - 8 panels on the roof.
Battery EP6 version 1.012
Inverter AC1-3-7-E-G2
Firmware:
Master 1.57
Slave 1.04
Manager 1.76
Dongle W6 version 1.10
Where do I go from here?
Thanks in advance
Re: Battery not charging after firmware update, yes, I have restarted my setup.
Can you see a SoC reading on the Inverter screen?
In the App, you may have to re-pair your system to the router by the sounds of it.
Hi, yes, it's showing 15%
Below that: "Normal"
There's a green light underneath that and a blue network light to the left of the green light.
