no energy export to grid
Posted: Fri Jun 02, 2023 9:34 am
by laharkido
my energy generation from panels stops once battery is 100% full.
As soon as I switch on any load (e.g. oven) my panels start generating energy again.
Can anyone help?
Inverter: hybrid/AC H1-4.6-E AC1-4.6-E
battery: Mira-hv25
Re: no energy export to grid
Posted: Sun Jun 04, 2023 12:02 am
by SAC
Might be worth checking that the inverter is set to on grid in the menu it might be set to off grid. Also check the work mode is set to self use
Cheers
Posted: Sun Jun 04, 2023 10:39 pm
by laharkido
Thanks for hint will have a look.
Is there some spreadsheet with info what values should be seat for each menu item for UK (don't think I saw anything like that in user manual)?
Posted: Tue Jun 13, 2023 4:17 pm
by calum
The intention is that your installer should configure it correctly for you. Of course they may not have done so completely and or correctly.
Will (forum admin) has done a number of video guides here that may help you out.
Posted: Fri Jun 16, 2023 9:13 am
by laharkido
update:
I sent email to https://www.fox-ess.com/timeline/contact-support]
provided my model and serial No
They managed to alter some settings on their end and got it working.
