no energy export to grid
laharkido
my energy generation from panels stops once battery is 100% full.
As soon as I switch on any load (e.g. oven) my panels start generating energy again.
Can anyone help?
Inverter: hybrid/AC H1-4.6-E AC1-4.6-E
battery: Mira-hv25
SAC
Might be worth checking that the inverter is set to on grid in the menu it might be set to off grid. Also check the work mode is set to self use
Cheers
laharkido
Thanks for hint will have a look.
Is there some spreadsheet with info what values should be seat for each menu item for UK (don't think I saw anything like that in user manual)?
calum
The intention is that your installer should configure it correctly for you. Of course they may not have done so completely and or correctly.
Will (forum admin) has done a number of video guides here that may help you out.
laharkido
update:
I sent email to https://www.fox-ess.com/timeline/contact-support]
provided my model and serial No
They managed to alter some settings on their end and got it working.
