Can anyone advice how to wire and set up 2 x FOX ESS Hybrid 6kw Invertors as id like a total of 12KW supply. DO i need to set master & slave, any information please
We have
2 x H1-6.0-e Hybrid Inverters
2 x V2 BMS
6 x V2 HV2600 Batteries.
2 strings / arrays. 14 panels on each array.
I want to setup with 3 batteries on each inverter/BMS, Invertors are
Do bear in mind that you might not find it straightforward to export 12kW
Hi Richard -
Did you ever find the solution?
I too have two H1 inverters (5kw).
At the moment one is acting as a non-hybrid inverter in series to the other.
I would also like to attach batteries to both inverters, so presumably any solution you found should work for me too!
