How easy to add a battery?
Posted: Thu Mar 26, 2026 3:39 pm
Hello forum,
I've had quotes for install of Fox ESS H1 G2 6.0kW 1ph Hybrid inverter and 2 or 3 Fox ESS EP12 Plus 11.52kWh batteries.
The mark up on the batteries is quite a bit. I totally understand there will be some mark up, but I'm trying to limit the spend.
What I'm considering is going ahead with just 1 battery fitted by MCS installer and adding extra at a later date.
Would it be straight forward to add another battery or batteries?
Thanks in advance
Thanks in advance
