Mira Hv25 Battery output
Posted: Sun May 21, 2023 9:30 am
by Gregson
Hello I wonder if someone could tell me what the max capacity (watts) the batteries should be able to output at once?
I have 3 x Hv25 batteries I find that sometimes with full batteries we still pull energy from the grid when cooking eg hob / oven... Thanks
Re: Mira Hv25 Battery output
Posted: Sun May 21, 2023 10:15 am
by SAC
You restricted by the output of your inverter normally 3.68kw in most cases. When using oven and hob you will find oven will draw 2.5kw and an average hob ring will draw 1.5kw so 4kw. 3.68kw coming from the inverter and the other 300w coming from the grid.
Don’t know what size inverter you have. But the batteries will only discharge 3.68kw for a 3.68kw inverter.
Hope this helps
Posted: Mon May 22, 2023 9:37 am
by calum
We have a 3.7kW H1 as well and while sometimes I wish we'd gone for the 5kW, most of the time it wouldn't make a difference. If you're trying to avoid / reduce grid draw, you have to bear in mind the 3.6kW limiter and eg pre-heat the oven before you start using the hob. Ovens will use a lot when warming up, but less when up to temp.
Posted: Tue May 23, 2023 12:43 pm
by Gregson
Thank you for the replies that all makes sense and explains it
Posted: Tue May 23, 2023 9:03 pm
by Ched
I have noticed that when it's nice and sunny I can pull almost 4kw from solar&batteries before any grid import happens.
