Unexpected and unrequested firmware update 2 March 2026
Posted: Mon Mar 02, 2026 6:25 pm
by UK_KH_User123
Hello!
After losing power to my house (because it runs off the EPS output of my KH10.5) I discovered the inverter just had an update pushed to it which I did not request from my installer, nor from Fox, nor from the app itself (which only a week ago appeared the option to request an update manually).
It pushed me thusly:
Went from Manager 1.37 to 1.58
Went from Master 1.41 to 1.60
'Slave' unchanged at 1.01
This has never happned to me before (2.5 years on). I previously have emailed Fox UK support and requested an update.
Anyone else had this experience?
Is it correct 'slave' still sits at v 1.01?
I have a call in to my installer to see if he pushed it. Thanks for any insights!
Re: Unexpected and unrequested firmware update 2 March 2026
Posted: Mon Mar 02, 2026 6:44 pm
by MaterialBarracuda48
Check the same question I asked about the Slave.
Dave replies 1 post below.
viewtopic.php?p=12031#p12031
Posted: Mon Mar 02, 2026 6:50 pm
by UK_KH_User123
Thanks for the link.
The strange thing is, after writing that, I noticed that the app update area shows that one "upgrade" is available and that is to take 'slave' from 1.01 to 1.02.
I haven't pushed that 'Upgrade Now' button yet but it is tempting so at least all three are up-to-date.
Posted: Mon Mar 02, 2026 6:52 pm
by UK_KH_User123
Oh, now I see that my data logger (W4 type) has an update available from 4.12 to 4.14. "Upgrade Now"???
<edit> I did it. Was quick and seems to still be working.
Posted: Mon Mar 02, 2026 7:26 pm
by UK_KH_User123
MaterialBarracuda48 wrote: ↑Mon Mar 02, 2026 6:44 pm Check the same question I asked about the Slave.
Are you on 'slave' 1.02 with your KH? I may push the button so at least I'm in control of the timing.
Posted: Mon Mar 02, 2026 7:56 pm
UK_KH_User123 wrote: ↑Mon Mar 02, 2026 7:26 pm Are you on 'slave' 1.02 with your KH? I may push the button so at least I'm in control of the timing.
Yes I am on v1.02
Posted: Mon Mar 02, 2026 7:59 pm
by UK_KH_User123
Cool, thanks! ... I figured since 1.02 is the listed current version and it was offered I should keep the versions in-sync with each other. So I pressed the update button in the app and it successfully updated. That update did not cause a full inverter reboot so it didn't cause problems. I'm not sure if it's the manager or the master that causes the full reboot which kills the EPS output.
Posted: Mon Mar 02, 2026 8:07 pm
Makes sense that you are now up to date, at least mine has carried on working.
Posted: Tue Mar 03, 2026 6:36 pm
by UK_KH_User123
I contacted my installer who said he did not push the update. So I guess FoxESS has started doing this themselves.
Since I run local control with Modbus and I don't need the Fox Cloud, I have decided to block that communication at my router. Easier than unplugging the datalogger but with similar results.
If there’s an update that I should get I can unblock it and request it from the app (or from my installer or FoxESS UK support).
I feel safer this way, from hacking (it is certainly possible) or malicious actions from inside FoxESS (who could be compelled by the CCP in a time of war, or any time they feel lke it, though obviously it would hurt their industrial exports), and also from the comparatively minor issue of a pushed update with no warning which powers down my house when the inverter reboots. Note - that happens to me because I run the house off of EPS. I think people who run the ’normal way’ would not notice the reboot.
Posted: Tue Mar 03, 2026 6:45 pm
It happened to me the other day as well, like you I lost my EPS when the Master updated as it reboots the inverter - I am the user, installer and agent for my system so it could only have been Fox. I suspect because of all the issues with the latest app update and the scheduler incompatibilities with different inverters/firmware combinations, Fox are in the process of force pushing their latest firmware out to all users (whether you want it or not).
Definitely a warning for EPS users, I nearly pulled my datalogger out so it cannot happen again… still dwelling on that.
Posted: Tue Mar 03, 2026 6:46 pm
Rather interesting if Fox pushed this through. I wonder if others will have the same treatment of pro-active rollout.
Posted: Tue Mar 03, 2026 6:52 pm
by UK_KH_User123
Dave Foster wrote: ↑Tue Mar 03, 2026 6:45 pm It happened to me the other day as well, like you I lost my EPS when the Master updated as it reboots the inverter - I am the user, installer and agent for my system so it could only have been Fox. I suspect because of all the issues with the latest app update and the scheduler incompatibilities with different inverters/firmware combinations, Fox are in the process of force pushing their latest firmware out to all users (whether you want it or not).
Probably ... supporting a wide range of installed versions would be tough. Maybe it will end up as a benefit in the long run.
Posted: Tue Mar 03, 2026 7:00 pm
I see Dave posted up the same thing as you, well at least you confirmed it had to have been Fox doing it pro-actively.
I guess there was nothing on their website to suggest they are going to be rolling out updates? They seem to know how to piss off their users :cry:
Posted: Wed Mar 04, 2026 2:44 am
by evilbunny
Dave Foster wrote: ↑Tue Mar 03, 2026 6:45 pm Definitely a warning for EPS users, I nearly pulled my datalogger out so it cannot happen again… still dwelling on that.
We had a long wait between ordering an install and actually getting the install done due to a long list of things like grid approval, storms likely on install dates and so on.
I ended up upgrading 2 old UPSes with dead LABs in them to have 2x50Ah LFPs because the UPSes are 24v, due to different charging voltages the batteries only charge up to about 80%, so pros and cons.
So while we're on the EPS circuit for the light circuit and power point circuit, only appliances and lights would go out. :D but we'd suddenly import from the grid too, which would be a pain at the wrong time. :(
Posted: Wed Mar 04, 2026 7:55 am
evilbunny wrote: ↑Wed Mar 04, 2026 2:44 am
Thanks, I used to have a small UPS but the EPS has been very effective and ditched it a couple of years back when the lead acid’s needed replacing, but to protect the essential stuff when the inverter is rebooting I think it’s time to re-look at a small LFP powered UPS.
Posted: Wed Mar 04, 2026 8:00 am
by evilbunny
Dave Foster wrote: ↑Wed Mar 04, 2026 7:55 am Thanks, I used to have a small UPS but the EPS has been very effective and ditched it a couple of years back when the lead acid’s needed replacing, but to protect the essential stuff when the inverter is rebooting I think it’s time to re-look at a small LFP powered UPS.
This came up the other day elsewhere https://au.ecoflow.com and they make LFP UPS
Posted: Wed Mar 04, 2026 9:51 am
by UK_KH_User123
I just ordered one of these: https://uk.ecoflow.com/products/river-3 ... 2824856915
Claim to have switchover speed comparable with a UPS -- and cheaper than similar capacity ups -- and the batteries should last longer due to being LiFePO4.
Posted: Wed Mar 04, 2026 10:50 am
I grabbed a Bluetti AC180 for my UPS needs, I can confirm it works during a power outage.
https://bluettipower.co.uk/products/blu ... er-station
That looks good for the price per kWh
UK_KH_User123 wrote: ↑Wed Mar 04, 2026 9:51 am I just ordered one of these: https://uk.ecoflow.com/products/river-3 ... 2824856915
