Solar production, Load and Grid values in graphical display in App do not report properly (
Posted: Thu Feb 26, 2026 4:32 pm
My system uses an H1-11.4-US
This is a grid tied inverter with no batteries.
The system needs to limit its total power pushed back onto the grid to be limited to 10.1Kw, as dictated by the utility company
For this reason I have installed the current transformers as directed, on the input from the Utility Meter where they would measure total current flow to and from the Grid.
I installed the current sensors on at the connection to the grid, because I want the inverter to provide the power to the cabin and only limit the inverter to what was allowed to be pushed to the grid after the cabin is supplied.
The inverter is connected into the main panel through a 60A breaker
When there is no solar generated, load and grid power are identical. The load is say 1Kw (Showing as red and negative) and the grid supplies 1Kw (Showing as blue and positive). The is typical consumption for this cabin.
However, as solar production increases (in the morning, after dawn for instance), the values of load are altered by the amount of solar being generated, even though the load had not changed.
For instance, when the solar is producing 5kW, the load shows as -4kW (now on the opposite side of the graph), which is the nominal 1kW load being consumed by the cabin minus the 5kW output that is being supplied by the solar panels.
Because the current sensors are on the utility meter, they are measuring net load (Cabin load - Solar supply)
So this throws off the actual cabin load value by the amount of solar being produced.
This error doesn't just affect the graphical display, but all other values for the day and accumulated values.
It seems to me that if the Inverter doesn't know its own power output without those current sensors, then it needs to measure its own output. Then it could measure Total output to the grid (which it needs to be compliant) and total output from the Inverter. By subtracting the two it could then know Cabin load.
The system needs to report both load and solar generation as separate and correct values.
Has anyone also seen this behavior? How do I go about properly setting that up?
