Watt Hour Sensor
I wrote this sensor after ongoing discussions with Ryan Morgan about some of the issues he has experienced with his battery pack - one of the key metrics he needed to know was how it is performing and this came from a rough in the head calculation of watt hour / % SoC.
In an ideal world this would be whatever your expected battery pack capacity is in watts and divide by 100 - so assuming 6 HV2600 batteries (6*2,560wh) = 15,360 / 100 = 153.6 watts per % change in SoC.
As a precursor, it is worth pointing out that the battery SoC on LFP batteries is notoriously unreliable but when taken over a larger range (say 20%) accuracy improves and it will give you a reasonable representation of how the pack is performing over time.
Known issues - more a known problem of LFP batteries reporting SoC, but over a longer period of time (>8 hours) where there is patchy solar and repeated charge / discharge in the battery and the SoC neither goes up or down much ,the accuracy falls as efficiency and granularity errors creep in.
Clearly the best accuracy comes from the simple use case where you charge the batteries up and then discharge the batteries.
To minimise this effect the sensor resets itself at 100% and 10% SoC (the BMS itself resets some of its counters) and also where the difference in SoC since last measurement is zero and if the nett change in SoC is > 19% (so in effect the measurement is taken up to and over a 20% range). Any values greater than 25% above/below expected are rejected.
It requires 3 helpers, 4 sensors and an automation that checks for changes and calculates the watt hour display.
HELPERS
Last SoC - used to record last soc state and only update when state changes, set as follows -
Starting SoC - used to record the starting position of SoC and is used as the divisor by the calculation, set as follows -
Watt hour calc - the sensor that holds the currently calculated watt hour usage, set as follows -
Now onto the sensors
batt_watt_change - a rolling sensor that counts every watt of either charge (+) or discharge (-)
  - sensor:
      - name: "batt_watt_change"
        unit_of_measurement: "W"
        device_class: power
        state_class: measurement
        state: >
           {{ (( ( (states('sensor.battery_charge') | float(default=0) * 1) - states('sensor.battery_discharge') | float(default=0)) * 1000)) | round(0) }}
Batt_wh_test - a Riemann sum integral of the watt hour counter
  - method: left
    platform: integration
    round: 2
    source: sensor.batt_watt_change
    unit_time: h
Batt_wh_count - a utility meter used to hold the Riemann sum counter value, and is reset by the automation to start/stop measurement periods
utility_meter:
  batt_wh_count:
    source: sensor.batt_wh_test
    cycle: monthly
    net_consumption: True
Battery_Wh_Display - a filtered version of batt_wh_calc that smooths steps as the SoC changes - this is the one to display on your dashboard.
  - platform: filter
    name: "Battery Wh Display"
    entity_id: input_number.watt_hour_calc
    filters:
      - filter: time_simple_moving_average
        window_size: "00:30"
      - filter: lowpass
        time_constant: 20
And finally the Automation (note this has been set for a 6 pack HV2600 with expected 153wh/% change )
alias: Check SoC
description: ""
trigger:
  - platform: time_pattern
    seconds: /30
condition:
  - condition: or
    conditions:
      - condition: numeric_state
        entity_id: sensor.battery_soc
        above: input_number.last_soc
        below: input_number.last_soc
action:
  - if:
      - condition: template
        value_template: >-
          {{  (states('sensor.battery_soc') | int(0) == 100) or
          (states('sensor.battery_soc') | int(0) == 10 ) or
          (states('input_number.starting_soc')  | int(0) ==0 ) }}
    then:
      - service: input_number.set_value
        target:
          entity_id: input_number.starting_soc
        data:
          value: "{{ (states('sensor.battery_soc') | int(0)) }}"
      - if:
            above: 99
        then:
          - service: utility_meter.calibrate
            data:
              value: "0"
            target:
              entity_id: sensor.batt_wh_count
            data:
              value: 154
            target:
        else:
          - if:
                below: 11
            then:
                data:
                  value: "0"
                target:
                data:
                  value: 154
                target:
            else:
                data:
                  value: "0"
                target:
                data:
                  value: 154
                target:
    else:
      - if:
            value_template: >-
              {{ (( ((states('sensor.battery_soc') | int(0) - states('input_number.starting_soc')|int(0) ) ) == 0) or (states('sensor.battery_soc')|int(0)-states('input_number.starting_soc')|int(0))|abs > 19 ) }}
        then:
            data:
              value: "0"
            target:
          - if:
                value_template: >-
                  {{ (states('sensor.battery_soc')|int(0)-states('input_number.starting_soc')|int(0))|abs > 19 }}
            then:
                target:
                data:
        data:
          value: >-
            {% set expectwh = 154 %} {% set Batsoc = states('sensor.battery_soc')|int(0) - states('input_number.starting_soc')|int(0) %} {% if Batsoc > 0 %}
              {% set whtest = ((states('sensor.batt_wh_count')|int(0))|abs / Batsoc) | round(2) %}
            {% else %}
              {% if Batsoc == 0 %}
                {% set whtest = expectwh %}
              {% else %}
                {% set whtest = ((states('sensor.batt_wh_count')|int(0))|abs / Batsoc|abs) | round(2) %}
              {% endif %}
            {% endif %}
            {% if whtest > (expectwh*1.25) or whtest < (expectwh*0.75) %}
            {% endif %} {{ whtest }}
        target:
    data:
      value: "{% set Batsoc = states('sensor.battery_soc')|int(0) %} {{ Batsoc }}   "
    target:
      entity_id: input_number.last_soc
mode: single
The results look something like this over 24 and 12 hours ( for a 7 pack system ~ 180wh / % expected ) -
