Missing several battery data information
Posted: Mon Feb 09, 2026 7:38 am
by James.huang10
Hi guys,
Looking for some assistance here from you experts. I seem to be missing alot of battery related data, i noticed this was the case when the system was first installed last year but never thought much about it as it was working fine. But now that I am learning a lot more, I'm looking to integrate a dashboard into my HA. I've attached 3 screenshots which show manufacturing date, remaining capacity data and nominal energy data all missing just to name a few. Is anyone able to shed some light as to how I can get this fixed?
Thanks heaps in advance :D
Re: Missing several battery data information
Posted: Mon Feb 09, 2026 8:59 am
by MaterialBarracuda48
Odds are you have an older firmware running on what looks like EP11's.
IIRC I had data missing from FW entries until the FW was updated.
https://www.fox-ess.com/contact-us
Scroll down to Global Service Contacts, and find either the email address or phone number for your region.
If you call, have ALL of your serial numbers available for Inverter/Datalogger/and every battery to hand.
Posted: Mon Feb 09, 2026 9:03 am
by James.huang10
MaterialBarracuda48 wrote: ↑Mon Feb 09, 2026 8:59 am Odds are you have an older firmware running on what looks like EP11's.
Thanks so much, I'll give that a go first. I thought I had all the firmwares updated recently when I got the datalogger and inverter updated for 5s refresh but turns out batteries didnt get updated.
Posted: Mon Feb 09, 2026 9:10 am
James.huang10 wrote: ↑Mon Feb 09, 2026 9:03 am Thanks so much, I'll give that a go first. I thought I had all the firmwares updated recently when I got the datalogger and inverter updated for 5s refresh but turns out batteries didnt get updated.
Are you running EP11's then?
Mine was on 1.005 upon install, and I am certain that some values were missing for me.
Do you have current FW version?
Posted: Mon Feb 09, 2026 9:14 am
by James.huang10
MaterialBarracuda48 wrote: ↑Mon Feb 09, 2026 9:10 am
correct, mine are ep11 and i just checked and the firmware I;m currently on is 1.003, looks like it's VERY outdated since the current version is 0.012
Posted: Mon Feb 09, 2026 9:16 am
I thought mine was on an older FW :D
Anyhow, report back once you have done your upgrade, I am sure it will be good once done.
Posted: Thu Feb 12, 2026 1:30 pm
by James.huang10
MaterialBarracuda48 wrote: ↑Mon Feb 09, 2026 9:16 am I thought mine was on an older FW :D
Thanks so much for your help, confirming all working now with the data now showing correctly. Seems i had a very outdated firmware!
Posted: Thu Feb 12, 2026 1:39 pm
James.huang10 wrote: ↑Thu Feb 12, 2026 1:30 pm Thanks so much for your help, confirming all working now with the data now showing correctly. Seems i had a very outdated firmware!
Top stuff!
Glad it is now showing the missing sections for you.
