I have just updated my Android phone Fox app to 2.2.0.
I have solar panels and batteries and I export to the grid. I need help in setting up the Total Revenue tab. It was set up in the older app but now asks me configure it.
OK, it says no Tariff Plan, so I go to create one. I select GBP(£) and manual set up. Under TOU Tariff Plan, it asks for Peak times. I am on Economy 7 with peak times being 0730-0030. When I input these times, it says that the end time must be greater than the start time. What am I doing wrong?
I want to set peak times to 0730-0030 and off peak to 0030-0730
I don’t use it myself but I think it’s complaining about the wrap around midnight - try adding 2 peak periods 07:30-23:59 and 00:00-00:30
Hi Dave,
Thank you for your suggestion. Unfortunately, I can only set imes in 15 minute blocks, so 23.59 is not possible.
I can set 0730-2345 and another slot from 0000-0030. Will the 15 minute "gap" affect the tariff plan calculations?
OK, I have had to make it into 0730-2400 and another 0000-0030...now it works!!
