Page 1 of 2
Is anyone getting a response from Fox Support?
Posted: Mon Jan 05, 2026 12:05 pm
by albie999
Thought I would raise it on here, as right now ... Fox do not seem to be responding to any emails
I am having the heater issue with the EP11 ... and originally raised this on 17th December ( I had actually raised this issue before with them, and the flashed firmwares .. but still not fixed)
I followed up on the 19th, asking if the heater issue had been fixed, where the response was "you already have the latest version" ... whcih is 1.09 .. but believe there is newer now (1.011)
I have since sent them various screenshots of the battery heater issue (which is being discussed on this thread .. (viewtopic.php?t=1603) ... but not getting a response
Re: Is anyone getting a response from Fox Support?
Posted: Mon Jan 05, 2026 12:54 pm
by MaterialBarracuda48
Not sure if they have closed your ticket off.
If it helps you, as mentioned in another thread, I have requested upgrade of BMS firmware from v1.009 to v1.011 (or whatever is latest)
Mon 5th Jan 09:53
Ticket ID ##98549##
Posted: Mon Jan 05, 2026 1:46 pm
by albie999
Not the response I wanted .... or expected .... looks like they are not reading the ticket correctly on my info provided .. so I have sent it again .. lets see what the response is
Posted: Tue Jan 06, 2026 11:00 am
by brunofabre
What country are you in? I am in Australia and have never had any reposnse to tickets I have raised (over 1 month ago). If you can get through, the telephone is the only way to contact them.
Posted: Tue Jan 06, 2026 11:01 am
by albie999
Am based in the UK ..... I did get a response, but it just felt like they did not actually read my issue. I have sent another chase email this morning, as still did not get the response ... .lets see
Posted: Tue Jan 06, 2026 12:52 pm
MaterialBarracuda48 wrote: ↑Mon Jan 05, 2026 12:54 pm Not sure if they have closed your ticket off.
Mon 5th Jan 09:53
Ticket ID ##98549##
Tue 6th Jan 11:38 - Inverter Manager FW upgraded
Update for you, they have not yet replied to ticket, and have upgraded Inverter FW (I asked for BMS and Inverter)
Posted: Tue Jan 06, 2026 4:02 pm
06th Jan 16:00 - ##98549##
Created a new ticket as they did half the job this morning
Applied FW to Inverter, but not the Battery I asked for as well.
Posted: Wed Jan 07, 2026 8:02 am
by albie999
I am having serious worries at the level of knowledge from the Fox support person (who I am dealing with) ... sent all my graphs / screenshots showing the issue, and woke up to this response below today
The "timeframe" they have looked at 12am - 5.30am .. is when I have my batteries in "charge from grid" due to Octopus cheap time (on IOG) ... obviously, have responded advising they look at the data I have sent
Posted: Wed Jan 07, 2026 9:51 am
I guess they took a look at your IOG Charge/Heat schedule and think everything is working fine.
Well yes, it is heating and charging to 100% SoC.
Then missing the point that the battery stops working at other times of the day, due to being cold and locking out the energy, or locks due to a heating cycle starting.
Posted: Wed Jan 07, 2026 5:21 pm
by Kosymodo
I think Support must be using all their time replying to my ticket, as I get multiple updates on it every day :D
Doris is my contact on my current ticket, and invariably it's Tristan who works on any tickets I place re firmware updates.
Now I know that by posting my tale of success, I've totally jinxed getting any further support :wink:
Posted: Wed Jan 07, 2026 5:35 pm
Kosymodo wrote: ↑Wed Jan 07, 2026 5:21 pm I think Support must be using all their time replying to my ticket, as I get multiple updates on it every day :D
I will send you my battery SN then, maybe they can upgrade me.
1st ticket I asked for Inverter and battery upgrade, they did inverter.
2nd ticket, never got anything
3rd ticket... well I await FW update
Posted: Wed Jan 07, 2026 5:42 pm
by Kosymodo
MaterialBarracuda48 wrote: ↑Wed Jan 07, 2026 5:35 pm
I've just this minute requested an inverter ARM upgrade and a battery BMS upgrade. Let's see if my request is more successful than yours!
Posted: Wed Jan 07, 2026 5:47 pm
Kosymodo wrote: ↑Wed Jan 07, 2026 5:42 pm I've just this minute requested an inverter ARM upgrade and a battery BMS upgrade. Let's see if my request is more successful than yours!
Best of luck with that, you have a golden ticket for sure :P
Posted: Thu Jan 08, 2026 9:30 am
I have finally got a reply from Fox Support, they have upgraded FW on Inverter and Battery.
The Inverter Slave is still 1.01, with current version 1.02 not sure what this does, but asked if they can look at this also.
Posted: Thu Jan 08, 2026 10:01 am
by Kosymodo
MaterialBarracuda48 wrote: ↑Wed Jan 07, 2026 5:47 pm
All done! Joanna did it for me this time though, not the usual Tristan :D
Posted: Thu Jan 08, 2026 10:14 am
Kosymodo wrote: ↑Thu Jan 08, 2026 10:01 am All done! Joanna did it for me this time though, not the usual Tristan :D
Joanna emailed me this morning too, asked for Inverter SN that is in the tickets, but supplied again and will see if the Inverter slave gets upgrade.
Posted: Thu Jan 08, 2026 10:44 am
Joanne has just emailed me to say the Inverter had been upgraded, from 1.01 to 1.01 :?
Posted: Thu Jan 08, 2026 11:07 am
All credit to Joanne, she did email me to say that the Inverter Slave was reading as 1.02.
For some reason the Modbus is reading 1.01 as seen above, Fox Cloud 2.0 App shows the correct 1.02.
ETA: I did just perform a HA Core update, and upon reboot it is now reading correct.
Posted: Thu Jan 08, 2026 12:43 pm
by retsplines
Did it change anything though? :)
I've been through several "upgrade" requests now and my Slave firmware has always stayed at 1.01 weirdly (even in the Fox portal).
Posted: Thu Jan 08, 2026 12:51 pm
retsplines wrote: ↑Thu Jan 08, 2026 12:43 pm Did it change anything though? :)
No idea :D
I don't have a clue what the Slave actually does in the system, runs the core OS? I have had a few FW upgrades to the Inverter and each time they leave the Slave on 1.01 until today.
Maybe @Will or @Dave know what it does.
Posted: Thu Jan 08, 2026 3:30 pm
Master and Slave are at the core of the system and look after the power flows and all of the real time events and inverter limits.
The Slave executes and follows commands from the Master and looks after control functions (such as MPPT’s) but after it’s first release it doesn’t usually see many/any version changes - Master is where the core level of control, parameter passing, grid interaction etc.. takes places.
Manager (aka ARM) is where the highest level of commands are managed, settings, scheduler, charging periods, external communications etc..
Posted: Thu Jan 08, 2026 3:32 pm
Thanks for clearing that up Dave, appreciated.
Posted: Wed Jan 14, 2026 8:51 am
by albie999
Honestly, if I still had hair .. I would be pulling it out ;-)
Just chased Fox Support, regard my ongoing issue with heater issue and lack of discharge and "reboot", and got the below response ... I am sure they are not relooking at what has been previously discussed
I have responded with
Posted: Wed Jan 14, 2026 9:24 am
by albie999
After chasing ... got a response .. and they have upgraded the battery firmware to 0.013
Posted: Wed Jan 14, 2026 9:54 am
by Kosymodo
albie999 wrote: ↑Wed Jan 14, 2026 9:24 am After chasing ... got a response .. and they have upgraded the battery firmware to 0.013
That's not current firmware though is it? Mine is on 1.011
