How do I give view-only access to my tenant for the new battery and inverter. If they use the Datalogger SN, they get full access to change settings... Anyone know?
I do not believe this is possible, they didn't setup system for Landlord/Tenant access in mind.
The only option is going to take a bit of work which involves setting up a home assistant using the OpenApi cloud access (much like the app)
You can then configure your dashboard to show inn their browser whatever information you want, and they cannot modify it.
