I am looking at adding Modbus integration to my H3 inverter. My plan was to power the adaptor using the usb port on the bottom of the H3. I know this port is only for diagnostics, but does anyone know if can/will provide enough power to run an Elfin dongle?
Thanks,
James
16 x 500W All Black, Bifacial DMEGC Panels - 8kW
FoxESS EP11 10.36kWh Battery
FoxESS 8kW 3 Phase H3 Inverter v2.08
sadly not enough power from the USB port, would need to be powered from a socket or I believe some of the efin adapters support POE if you have POE on your network switch to use.
