H1-gen2 using a W6 model datalogger - AVOID v1.07
Posted: Tue Jun 24, 2025 7:05 pm
by Will
H1-gen2 using a W6 model datalogger, do not update to 1.07, as there is a firmware bug that prevents cloud communication, similar to the issue I observed in the WW logger software a month ago. hold on 1.06 until 1.08 is out.
Re: H1-gen2 using a W6 model datalogger - AVOID v1.07
Posted: Fri Jun 27, 2025 1:08 pm
by Will
To avoid this issue, make sure you update the manager firmware to 1.54 or later before you update the logger firmware.
Posted: Thu Sep 11, 2025 7:37 pm
by KelEl
What if you didn’t see this and upgraded…….
How do i fix it?
Posted: Thu Sep 11, 2025 7:38 pm
by Will
If you have a problem, simply upgarde the manager version to latest which resovles it or downgrade the logger version.
Posted: Thu Sep 11, 2025 7:40 pm
by KelEl
Will wrote: ↑Thu Sep 11, 2025 7:38 pm If you have a problem, simply upgarde the manager version to latest which resovles it or downgrade the logger version.
Won’t let me upgrade the manager version as says the inverter is offline and can’t see a way to downgrade the logger version
Posted: Thu Sep 11, 2025 7:42 pm
by Will
So remember it can take 10 minutes for the firmware to complete before the site appears online again.
If you're still having issues message back here.
Posted: Thu Sep 11, 2025 7:43 pm
by KelEl
Will wrote: ↑Thu Sep 11, 2025 7:42 pm So remember it can take 10 minutes for the firmware to complete before the site appears online again.
Been offline since yesterday. Done a full restart and all sowing as normal on the front panel but won’t show as connected on the app.
Posted: Thu Sep 11, 2025 8:53 pm
by Will
I would drop fox support a message and see if they can downgrade you or resolve it remotely.
Posted: Sat Sep 20, 2025 8:58 pm
by KelEl
Will wrote: ↑Thu Sep 11, 2025 8:53 pm I would drop fox support a message and see if they can downgrade you or resolve it remotely.
So they sent me out a new datalogger. Plugged it but its says its not associated with an inverter. Help!!!!!
