work model feed-in priority with Mode Scheduler
Posted: Mon Jun 23, 2025 3:13 pm
Hi!
First off thanks for all the useful info here, i have already learned a lot!
I have a KH9 + EP11 setup, on Octopus Agile + Fixed export
I am trying sell all PV during the day + setup cheap battery charging using the Agile functionality in the mode scheduler
When I try to set the Work model to Feed in priority it seems to disable the Mode scheduler, and if I re-enable the scheduler it resets the Work model back to self use.
Is this expected?
Is there any way to use the agile scheduler for charging battery and use feed in priority?
Cheers!
Is this expected?
Cheers!
